Tire Pressure Recommendation with Eibach Lowering Springs
Orem
UT
Does anyone know if there is a recommended tire pressure we should be running for the 19" Michelins with the Eibach lowering springs? Just want to make sure that I am doing everything I can to avoid unnecessary tread wear. Thanks guys!! fullsizeoutput_10aa.jpg
Tire pressure is independent of ride height. Follow the manufacturer recommendation and you will be ok. [like]
As long as your alignment is within spec you should not have problems with tire wear.
Also maintain the recommended tire pressure to maximize tread life.
