Stock Kia Stinger Wheel Information:
8.0J?18
8.0J?18
8.0J?19
8.5Jx19
18" Alloy Wheel (A-type)
18" Alloy Wheel (B-type - Premium Models)
19" Alloy Wheel (A-type - GT Models) #52910-J5220
19" Alloy Wheel (B-type - GT Models) #52910-J5210 (19x8), #52910-J5260 (19x8.5)
Kia Stinger Hub Centric Ring:
67.1mm Hub Centric Diameter
Kia Stinger Wheel Weight:
19" - 34lbs
Standard Kia Stinger Wheel Offset:
18" A-type - 34mm
18" B-type - 34mm
18" - 40mm
19" - 40mm
Depending on the wheel, you can go with an offset from 34mm to 42mm.
Kia Stinger Tire Sizes:
Michelin Pilot Sport 4 225/40/R19 & 255/35/ZR19 (Included)
Continental ContiSportContact 225/40/ZR19
Bridgestone Potenza RE97AS-02 225/45/R18 & 225/50/R17
17" Tires
225/50/R17
18" Tires
225/45 R18 (Recommended)
19" Tires
225/40 R19 Front (Recommended)
255/35 R19 Rear (Recommended)
Tire Pressure
18" - Cold
Front 225/45R18 - 36psi
Rear 225/45R18 - 39psi
19" - Cold
Front 225/40ZR19 - 36psi
Rear 255/35ZR19 - 36psi
19" - Cold
Front 225/40ZR19 - 38psi
Kia Stinger Spare Wheel & Tire Size:
17"x6"
Kia Stinger Bolt/Lug Pattern:
5x114.3 or 5x4.5
Kia Stinger Tire Pressure Sensors TPMS:
Ford Part# 52933 J5000
Kia Stinger Aftermarket Wheels:
https://www.kiastinger.org/forum/threads/118-Kia-Stinger-Aftermarket-Wheel-Options
8.0J?18
8.0J?18
8.0J?19
8.5Jx19
19" - 34lbs
18" A-type - 34mm
18" B-type - 34mm
18" - 40mm
19" - 40mm
17" Tires
225/50/R17
18" Tires
19" Tires
Tire Pressure
18" - Cold
19" - Cold
19" - Cold
17"x6"
5x114.3 or 5x4.5
